PROBLEM
Generally, if an organization's credit balance is negative, the members of the organization with analysis privilege still can access the Analysis button in ArcGIS Online map viewer, though errors are returned if performing analysis that consumes credits.
However in some cases, all members, regardless of their roles and privileges, are unable to access the analysis tools if the organization's credit balance is negative.
This issue occurs because the organization has the credit budgeting enabled. Some members may use ArcGIS credit-consuming functionality excessively and exceed the organization's credit allocation. When this happens, the subscription may become suspended or go into negative balance. As a result, the members lose the access to analysis tools.
Note: Members are not able to perform any analysis that consumes credits. The organization must purchase more credits to offset the negative balance.
Get help from ArcGIS experts
Download the Esri Support App
