HOW TO
Limit the results of the Search widget to a specific extent in Web AppBuilder for ArcGIS
Summary
The results of the Search widget can be limited to a certain extent in Web AppBuilder for ArcGIS by editing the config_Search.json file in [install dir]\server\[app#]\configs, and the Widget.js file in [install Dir]\server\apps\[app #]\widgets\Search.
Procedure
The following code segments demonstrate how to limit the results of the Search widget to a specific extent.
Add the searchExtent variables, consisting of the minimum and maximum x- and y- coordinates, as follows:
"type": "locator",
      "searchExtent": {
        "xmin": -9589858.361942431,
        "ymin": 3964964.109405532,
        "xmax": -9522593.777051566,
        "ymax": 4031693.635098401,
        "spatialReference": {
          "wkid": 102100
Following the code above, Extent is now required in the require list in the beginning of the script.
require([
   'esri/geometry/Extent',
   function()
The variables added in the config_Search.json file are then retrieved in the Widget.js file in [install Dir]\server\apps\[app #]\widgets\Search to create a new Extent object, referring to the minimum and maximum x- and y- coordinates set in the config_Search.json file.
if (source && source.url && source.type === 'locator') {
              locator: new Locator(source.url || ""),
              outFields: ["*"],
              singleLineFieldName: source.singleLineFieldName || "",
              name: source.name || "",
              placeholder: source.placeholder || "",
              countryCode: source.countryCode || "",
              maxResults: source.maxResults || 6
            if(source.searchExtent){
              locSource.searchExtent =  new Extent(source.searchExtent);
            return locSource;
Article ID:000014969
Software:
  • ArcGIS API for JavaScript 4 x
  • ArcGIS Web AppBuilder
  • ArcGIS API for JavaScript 3 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
