PROBLEM
Map is not displaying in a basic ArcGIS Runtime 10.2.7 application
On running a basic template-based ArcGIS Runtime 10.2.7 application within Visual Studio, the ArcGISTiledMapServiceLayer (map) does not appear in the main window of the app.
Cause
This issue may occur if using a virtual machine, such as VMware.
Solution or Workaround
The video/graphics card settings of the computer or device must match the Esri recommended system requirements, as specified in the System Requirements for ArcGIS Runtime 10.2.7.
  • Direct3D feature level 9_3
  • Default: DirectX 11 hardware support
  • 64 MB RAM minimum, 256 MB RAM recommended; NVIDIA, AMD, and Intel chipsets supported
  • Accelerated graphics card driver
  • Shader Model 2.0 minimum
If necessary, update the Guest Additions on the VMware virtualization software.
Article ID:000014549
Software:
  • ArcGIS Runtime SDK for NET 10 2 7
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
