HOW TO
Add hyperlinks to the footer of a pop-up window using ArcGIS API for JavaScript
Last Published: September 11, 2023
Summary
Adding a hyperlink to an InfoWindow footer (next to the Zoom to hyperlink) can be achieved by using the domConstruct.create function. The effect is as shown in the example below:
Photo example of hyperlink in footer of an InfoWindow
Procedure
The following script demonstrates how to add hyperlinks to the footer of an infoWindow.
Code:
var link = domConstruct.create("a",{
 "class": "action",
 "id": "statsLink",
 "innerHTML": "More Information", //the text representing the link
 "href": "javascript: void(0);"
 }, query(".actionList",map.infoWindow.domNode)[0]);
 on(link, "click", [function name]);
function cp(evt){
 window.open("http://url"); //set the url to be displayed
The code snippet can also be used to activate geoprocessing tools. For more information, refer to the following web help document: ArcGIS API for JavaScript: Geoprocessing tool link in popup
The code only works for ArcGIS API for JavaScript 3.x.
Article ID:000014528
Software:
  • ArcGIS API for JavaScript 3 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
