Is This Content Helpful?
How can we make this better? Please provide as much detail as possible.
Contact our Support Team
Attempts to use the replace() function in a Python script on a string field fail and return the following error:
Error: 'NoneType' object has no attribute 'replace'
The error occurs when there are Null values in the selected field. The following image shows an attribute table with a field containing Null values.
import arcpy cursor = arcpy.da.UpdateCursor ("[Feature]", "[Field Name]" for row in cursor: row[0] = row[0].replace("%20", " ") cursor.updateRow(row)
Use the selection clause to avoid executing the replace() function on Null values in the field. The following code sample demonstrates how to do so:
import arcpy cursor = arcpy.da.UpdateCursor("[Feature]", "[Field Name]") for row in cursor: if row[0] == None: row[0] = row[0] else: row[0] = row[0].replace("%20", " ") cursor.updateRow (row)
Last Published: 5/14/2019
Article ID: 000014467
Software: ArcMap 10.6.1, 10.6
