PROBLEM
Unable to select graphic elements from a map layout
Last Published: March 30, 2023
When working in layout view in ArcMap, graphic elements cannot be selected for editing or deleting. As shown in the following image, when attempting to select the shade awning layer represented by the dark rectangle using the Select Elements tool in layout view, the data frame is selected instead of the shade awning layer.
An image of the unfocused data frame.
Cause
Graphic elements in layout view are not selectable because the data frame within the layout view is not in focused mode.
Solution or Workaround
In layout view, focusing the active data frame allows users to work with features and elements in the data frame similar to working in data view. Users can create, delete, and edit features, graphics and text in a focused data frame.
When the data frame is focused, hashed border lines appear around the data frame as shown in the image below.
An image of a focused data frame.
To focus the data frame, use one of the following options:
  • Double-click inside the data frame.
  • On the Layout toolbar, click the Focus Data Frame The Focus Data Frame button on the Layout toolbar. button.
The image below shows that the shade awning layer in layout view is selectable after focusing the data frame.
Image showing that the graphic element is selectable in focused data frame.
Graphics can be selected using the Select Elements tool or keyboard shortcuts to edit the elements. For more information on how to select graphic elements, refer to the following documentation: About editing in layout view and Using the Layout window to select elements
Article ID:000014178
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
