Error: 000010: Geocode addresses failed
Error Message
When geocoding a table of addresses, the geocoding process fails and returns the following error:
Error: 000010: Geocode addresses failed.
Cause
This error occurs due to one or more of the following causes:
- Incorrect file format for the table of addresses.
- Inconsistent Excel formatting for field names.
- Duplicate fields in the table of addresses.
- The license level for ArcGIS Desktop is insufficient to perform the geocoding operation.
Solution or Workaround
Based on the cause, follow the respective solutions to resolve the issue.
- Ensure the table is saved as a CSV
Save the table of addresses as a CSV file and use the CSV file as the input for geocoding.
- Consistently format the Excel table
Ensure the table is formatted consistently for use in ArcGIS. Remove any spaces or special characters from the field names of the table of addresses. For more information, refer to ArcGIS Help: Formatting a table in Microsoft Excel for use in ArcGIS.
- Remove duplicate fields in the table of addresses
Remove and ensure there are no duplicate fields in the table of addresses before running the Geocode Addresses tool.
- Ensure the ArcGIS Desktop license level supports the geocoding methods
Some address geocoding methods such as the out_relationship_type method, are only supported with the ArcGIS Desktop Standard or ArcGIS Desktop Advanced licences. Ensure the license level is capable of supporting the geocoding methods used. For more information, refer to ArcGIS Help: Geocode Addresses.
Related Information
- ArcGIS Pro: 000010: Geocode addresses failed.
- ArcGIS Help: Understanding how to use Microsoft Excel files in ArcGIS
- FAQ: What are some best practices for batch geocoding addresses using the ArcGIS Online World Geocoding Service?
Last Published: 10/20/2017
Article ID: 000013875
Software: ArcMap 10.3.1, 10.3
