PROBLEM
When publishing feature services with Sync enabled and clicking Analyze in the Service Editor, the following error is returned:
Error: 00184: Layer is not configured for or cannot be used with the Sync capability
There are several causes for the error :
The feature service does not have a valid Global ID
For the service to use the Sync capability, all layers, whether version or nonversioned, require the Global ID field created by ArcGIS.
The data for the feature service is not registered as versioned or has archiving enabled
For a service with nonversioned data to use the Sync capability, the nonversioned data must be registered as versioned or have archiving enabled.
The feature service is registered as versioned with the option to move edits to base
Registering data as versioned with the option to move edits to base allows versioned edits on the data. However, when the data is registered as versioned with the option to move edits to base, the ArcGIS operation of replicating the geodatabase cannot be used. For more information, see the following ArcGIS Help fopic: A quick tour of registering and unregistering data as versioned. This prevents sync data from working because it requires a replica.
Note: If the feature dataset is already registered as versioned with the option to edit base checked, unregister the feature dataset first before registering the dataset again without the edit base option as instructed above.
Get help from ArcGIS experts
Download the Esri Support App
