ERROR
000824: The tool is not licensed
Error Message
Running a Python script to launch geoprocessing tools returns the error:
Error:
"000824: The tool is not licensed."
Cause
There are two possible reasons for this issue:
  • The ArcGIS for Desktop version installed is not licensed for tools in an extension.
  • The extension the tools are in is not checked out in the script. If this is the case, the tool is not available for use in the Python environment.
Solution or Workaround
Follow the suggested solutions provided to solve this issue:
  • Ensure the installation of ArcGIS for Desktop is licensed to use the tool. For example, the Spatial ETL tool is only available with the ArcGIS Data Interoperability extension installed.
  • Add the following code snippet to check-out the extension containing the tool before calling the tool for use:
import arcpy
arcpy.CheckOutExtension("[Extension name]")
#Sample code
import arcpy
arcpy.CheckOutExtension("DataInteroperability")
arcpy.KMLToGDBModel_DataInteropToolboxAlias(Source_Google_Earth_KML_File_or_URL_, Destination_Esri_File_Geodatabase_)
Inserting the snippet after the code segment to run the tool results in the script reading the tool as being unavailable as the extension is not enabled.
Article ID:000013100
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
