Frequently asked question
Is it possible to shorten the URL of a web application in Web AppBuilder for ArcGIS?
It is sometimes necessary to share URLs in an abbreviated form, and while it is not possible to shorten the URLs of a web application in Web AppBuilder for ArcGIS, there are alternative ways of doing this. There are JavaScript templates that provide this option, but there is no built-in functionality in the application. However, a URL can be converted into a QR code. Mobile devices with a QR code scanner can easily scan the code to view the application. For more information about sharing using QR codes, refer to the following web help document, Web AppBuilder for ArcGIS: Previews.
Alternatively, a third-party tool or a browser add-in, for example, Bitly, can be used to shorten and customize URLs as desired by the user.
Article ID: 000001158
Software:
  • ArcGIS Web AppBuilder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
