HOW TO
Note: This capability was introduced at ArcGIS Pro 3.1 - versions 3.0 and earlier do not possess this functionality.
Starting at version 3.1, ArcGIS Pro can now take advantage of the ARCTMPDIR Environment Variable, a mechanism which can be used to redirect where certain temporary and scratch files are stored on a file system.
Below are some examples of what types of files and/or processes will adhere to the implementation of an ARCTMPDIR Environment Variable if it iss present on a system:
Note: Not all temporary files ArcGIS Pro generates during usage will adhere to the implementation of ARCTMPDIR.Currently, ArcGIS Pro attempts to save temporary files in a downwards hierarchy; if a certain directory for temporary file storage isn’t found, it will attempt to use the next-available directory, and so on. As far as what this hierarchy looks like, and where ARCTMPDIR sits in relation to this, the following list of directories in a top-down order can be referred to:
variable name: ARCTMPDIR variable value: C:\temp
Note: Replace C:\temp in the above with a disk location appropriate for the current user. The current user must have full read/write access to this location.
Article ID: 000029492
Get help from ArcGIS experts
Start chatting now
