HOW TO
Generate a token for a federated ArcGIS Server that uses IWA SSO authentication using Python
Last Published: January 11, 2023
Summary
When requesting a token via Python, the request is technically anonymous. Since anonymous authentication is disabled at the Web Adaptor level when taking advantage of IWA SSO, a 404 unauthorized error is returned when trying to generate a token.
To work around this limitation, it is necessary to install the requests-negotiate-sspi module in the Python environment that we want to use to grant the "requests" module the ability to pass Windows credentials in requests.
Use the below sample script to generate a token using the credentials of the Windows account with which you run your script:
Procedure
import json
import requests
from requests_negotiate_sspi import HttpNegotiateAuth
portal = "https://hostname.domain.com/portal"
server = "https://hostname.domain.com/server"
def getPortalToken(url):
    parameters = {'client' : 'referer','referer': server,'expiration': 5,'f' : 'json'}
    req = requests.get(url + '/sharing/rest/generateToken?', parameters, auth=HttpNegotiateAuth())
    json = req.json()
    token = json.get("token", "")
    return token
def getServerToken(url, serverUrl, token):
    parameters = {'serverUrl' : serverUrl,'token' : token,'f' : 'json'}
    json= req.json()
    return token
portalToken = getPortalToken(portal)
serverToken = getServerToken(portal, server, portalToken)
print(serverToken)
Article ID: 000029103
Software:
  • Portal for ArcGIS
  • ArcGIS Server
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
