Problem: Fields are not displayed in ArcGIS Field Maps
When viewing the features in ArcGIS Field Maps, some fields are not displayed, as shown in the image below.
The field or attribute expression is not selected in the Pop-ups pane.
- Select the fields in ArcGIS Online Map Viewer.
- Log in to ArcGIS Online and click Content > My Content.
- Browse to the web map, click More Options
and select Open in Map Viewer. - On the Contents (dark) toolbar to the left of the page, click Layers
. - In the Layers pane, click the layer.
- On the Settings (light) toolbar to the right of the page, click Pop-ups
. - In the Pop-ups pane, under Options, click Fields list and click Select fields.
- In the Select fields pane, check the relevant fields or expressions, and click Done.
- Click Save and open
> Save.
- Reload the web map in ArcGIS Field Maps.
- Log in to the ArcGIS Field Maps app.
- In the Maps list, browse to the web map and tap the Overflow menu
. - Tap Reload Map.
The image below shows the features displayed in ArcGIS Field Maps.
Last Published: 11/24/2022
Article ID: 000028731
