HOW TO
In ArcGIS Pro, polyline features can be converted to a polygon feature using different geoprocessing tools depending on the type of license. The Feature To Polygon and Construct Polygons tools are available with either an ArcGIS Desktop Standard or Advanced license. With an ArcGIS Desktop Basic license, these tools are not accessible.
This article provides a workaround to convert polyline features to a polygon feature with an ArcGIS Desktop Basic license using the Merge and Autocomplete Polygon tools.
The polyline features below are used to demonstrate the workflow.
Note: This workaround does not replace the functionality of the Data Management toolbox. Upgrade to ArcGIS Desktop Standard or Advanced license to access more capabilities when converting features. Refer to ArcGIS Pro: ArcGIS Pro license levels for more information on the licenses.
Note: To convert polylines to polygons, ensure the polylines are enclosed. Add a new line to connect the points if necessary.
The polyline features are merged into a single polyline feature.
Note: The Autocomplete Polygon icon only displays when a polygon feature class is selected in the Create Features pane.
The polygon feature is created from the polyline features.
Article ID: 000028182
Get help from ArcGIS experts
Download the Esri Support App
