PROBLEM
New shapefile features do not display in all extents in ArcGIS Pro
Last Published: June 8, 2022
In ArcGIS Pro, when features are created in a shapefile, the features are displayed on the map and the attribute information is recorded in the attribute table. However, in some instances, the features do not display on the map when zooming in and only display when zooming out, as shown in the images below.
The features are not displayed when the map is zoomed in.
The map in ArcGIS Pro with the selected features  not displayed when zoomed in.
The features are not displayed when the map is zoomed out.
The map in ArcGIS Pro with the selected features  displayed when zoomed out.
Cause
The coordinate system of the shapefile is an unknown coordinate system. Therefore, the newly created features do not have spatial references to be displayed in all extents.
To check the coordinate system of the shapefile, refer to the Tip section in ArcGIS Pro: Specify a coordinate system.
The Layer Properties window displaying the spatial reference for the shapefile which is an unknown coordinate system.
Solution or Workaround
In ArcGIS Pro, define the coordinate system of the shapefile using the Define Projection tool.
  1. Open the ArcGIS Pro project.
  2. In the Geoprocessing pane, search for the Define Projection tool. Refer to ArcGIS Pro: Run a tool in the Geoprocessing pane for instructions.
  3. In the Define Projection pane, under the Parameters tab, click the drop-down arrow under Input Dataset or Feature Class, and select the shapefile.
  4. For Coordinate System, click Select coordinate system The Select coordinate system icon. to open the Coordinate System window.
The Define Projection pane with the note stating that the tool modifies the input dataset or feature class.
  1. In the Coordinate System window, expand Projected Coordinate System or Geographic Coordinate System to specify the coordinate system. In this example, WGS 1984 Web Mercator (auxiliary sphere) is selected. Click OK.
The Coordinate System window with the WGS 1984 Web Mercator (auxiliary sphere) selected.
  1. In the Define Projection pane, click Run.
The image below demonstrates the newly created features displayed when the map is zoomed in.
The map with all the selected features displayed when zoomed in.
Article ID: 000027718
Software:
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
