Summary
In some cases, when importing layers from another project in ArcGIS Online, the symbology is not preserved. This article highlights the workflow to transfer symbology from a feature layer to another layer in the admin REST endpoint in ArcGIS Online by copying its JSON script.
Procedure
- Copy the JSON script of the symbology.
- In ArcGIS Online, navigate to Content > My Content.
- On the My Content tab, select the item to open its item details page.
- On the item details page, select and click the feature layer containing the symbology.
- Scroll down to the URL section and click View. The page redirects to ArcGIS REST Services Directory.
- On the ArcGIS REST Services Directory page, under Layers, select and click the layer with the desired symbology. This article uses malaysia_poi as an example.
- Navigate to the Drawing Info section and copy the JSON script.
- Transfer the copied JSON script to another layer.
- Repeat step 1c through 1f. In step 1f, select the desired layer. This example uses malaysia_location.
To edit the JSON script, access the ArcGIS REST Administrator Directory.
- On the ArcGIS REST Services Directory page, in the browser address bar, replace ‘/rest/services/’ with ‘/rest/admin/services/’. Reload the page.
- Scroll down the page, under Supported Operations, click Update Definition.
- In the Update Layer Definition box, clear out the existing content. Add an opening curly bracket { in the first line, in the next line, type "drawingInfo":{ , then paste the JSON script from the first layer to the and add a closing curly bracket at the end } (similar to the format shown in the example and screenshot below).
"drawingInfo":{"renderer":{"type":"simple","symbol":
{"type":"esriSMS","style":"esriSMScircle","color":
[128,0,123,255],"size":4,"angle":0,"xoffset":0,"yoffset":0,"outline":"{"color":
[0,0,0,255],"width":1}}},"scaleSymbols":false,"transparency":0,"labelingInfo":null}
- Select True for ASync and select JSON for Format. Click Update Layer Definition.
* If the schema of your layers don't match, for example if the second layer is missing a field or a domain that is used in the symbology (i.e. referenced in the drawing info), updating layer definition may still return success but the symbology of the layer won't change.
