English
Error: ArcGIS Server Upgrade step 2 of 2: Failed. Synchronize with site
Error Message
Attempting to upgrade ArcGIS Server fails, and clicking 'Continue Server Upgrade' returns the following error message:
Error:
The error message returned when attempting to upgrade ArcGIS Server
Cause
  • The ArcGIS Server endpoint cannot be reached due to improper configuration of the server's security settings.
  • The ArcGIS Server account used during the upgrading process lacks the necessary permissions to the ArcGIS Server folders.
Solution or Workaround
Modify the security-config.json file to use the default server settings
  1. Stop the ArcGIS Server service. Refer to ArcGIS Server: Stop a service in Manager for the steps to do this.
  2. Navigate to the following directory:
C:\arcgisserver\config-store\security\security-config.json
  1. Open the security-config.json file using a text editor such as Notepad++.
  2. Modify the parameters in the code as follows:
      "securityEnabled": true,
      "authenticationMode": "ARCGIS_TOKEN",
      "authenticationTier": "GIS_SERVER",
      "userStoreConfig": {
        "type": "BUILTIN",
        "properties": {}
      "roleStoreConfig": {
        "type": "BUILTIN",
        "properties": {}
      "sslEnabled": true,
      "HSTSEnabled": false,
      "httpsProtocols": "TLSv1.2,TLSv1.1",
      "cipherSuites": "TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA, TLS_DHE_RSA_WITH_AES_256_GCM_SHA384, TLS_DHE_RSA_WITH_AES_256_CBC_SHA256, TLS_DHE_RSA_WITH_AES_256_CBC_SHA, TLS_RSA_WITH_AES_256_GCM_SHA384, TLS_RSA_WITH_AES_256_CBC_SHA256, TLS_RSA_WITH_AES_256_CBC_SHA, TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA, TLS_DHE_RSA_WITH_AES_128_GCM_SHA256, TLS_DHE_RSA_WITH_AES_128_CBC_SHA256, TLS_DHE_RSA_WITH_AES_128_CBC_SHA, TLS_RSA_WITH_AES_128_GCM_SHA256, TLS_RSA_WITH_AES_128_CBC_SHA256, TLS_RSA_WITH_AES_128_CBC_SHA",
      "httpEnabled": true,
      "virtualDirsSecurityEnabled": false,
      "allowDirectAccess": true,
      "serverRole": "STANDALONE_SERVER"
  3. Save the file and restart ArcGIS Server. Refer to ArcGIS Server: Start a service in Manager for the steps to do this.
Give permissions for the ArcGIS Server account to the necessary ArcGIS Server folders
Completing this workaround may require assistance from the organization's IT department
Provide permissions for the ArcGIS Server account to the ArcGIS Server folders in the following directories:
C:\Program Files\arcgis\server\
C:\Program Files\arcgis\server\framework\
C:\Program Files\arcgis\server\usr\
C:\Program Files\arcgis\server\bin\
C:\Program Files\arcgis\server\XMLSchema\
C:\Program Files\arcgis\server\DatabaseSupport\
C:\arcgisserver\ (or where the config-store and directories are located)
C:\arcgisdatastore\
C:\Program Files\ArcGIS\datastore\
C:\Python27
To provide permissions for the ArcGIS Server folders, follow the steps provided in the Solution or Workaround section of Error: The ArcGIS Server is not able to connect to the specified directory.
Related Information
Last Published: 12/3/2021
Article ID: 000026885
Software: ArcGIS Server 10.9.1, 10.9, 10.8.1, 10.8, 10.7.1, 10.7
