PROBLEM
Running the Near tool fails and returns Error 000499
Last Published: November 26, 2021
The Near tool is designed to calculate the distance and additional proximity information between or around the input features and the closest feature in another layer or feature class. In attempts to calculate the distance, the following error message is returned:
Error:
ERROR 000499: table is not editable
Error 000499
Cause
  • The tool is run on a non-editable file type, for example, SDC feature class. Refer to ArcGIS Pro: 000499: Table is not editable for more information.
  • The feature layer or feature class is set to the read-only mode.
Solution or Workaround
Based on the cause of the issue, use one of the solutions provided.
Convert the file to an editable file type
Use the Conversion tools available in ArcGIS Pro to convert the file. Refer to How To: Convert SDC Feature Classes using ArcToolbox for more information.
Grant full privileges to the file
Completing this workaround may require assistance from the organization's IT department.
  1. Locate the file in Windows Explorer.
  2. Right-click the file, and click Properties.
Right clicking the file in Windows Explorer, and click Properties
  1. On the General tab, under Attributes, uncheck Read-only.
Unchecked Read-only under Attributes in the General tab
  1. Navigate to Security, under Permissions for SYSTEM, check all the criteria under Allow. Click Apply.
All criteria under Allow are checked
The image below shows the Near tool is run successfully.
Near tool is successful
Article ID: 000026797
Software:
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
