HOW TO
Configure Legend Item for a layout in ArcGIS Pro using Python
Last Published: October 22, 2021
Summary
In ArcGIS Pro, categories to display in a layout legend can be selected in the Legend Item pane from the legend properties, as shown in the image below.
Legend Items pane in ArcGIS Pro when configuring legend properties
However, in ArcPy, the LegendItem class does not contain the method to select the categories to display. Refer to ArcGIS Pro: LegendItem for more information. To enable the category selection, the Python Cartographic Information Module (CIM) must be used in the script, and this article describes the steps to do so.
Procedure
  1. Set the desired workspace.
p = arcpy.mp.ArcGISProject('current')
lyt = p.listLayouts()[0]
  1. Get the layout CIM definition.
lyt_cim = lyt.getDefinition('V2')
  1. Iterate through all the layout elements to find the Legend element.
for elm in lyt_cim.elements:
  if elm.name == "Legend":
    #Legend item changes
    for itm in elm.items:
      if itm.name == "GreatLakes":
        #Update visibility
          itm.showLayerName = True
          itm.showHeading = False
          itm.showGroupLayerName = False
  1. Set the CIM changes back to the layout
lyt.setDefinition(lyt_cim)
The code block below demonstrates the full script.
#Get the layout's CIM definition
          itm.showLabel = True
Article ID:000026663
Software:
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
