HOW TO
This article describes the steps to import images from a drone to ArcGIS Flight and upload them to Site Scan. This article also details how to import images captured using a third-party flight control application and how to use the Quick Upload Copy functionality. ArcGIS Flight uses the iOS Files application to store and access images from drone missions. Using this native iOS application designed for managing large numbers of files simplifies image management and increases security by restricting access from third-party apps to your imagery.
The following section will provide workflows for common methods of importing imagery from your drone to your tablet and uploading imagery from your tablet to Site Scan. You may also upload images manually to Site Scan from a computer. To load images manually through a computer, see the article: How To: Upload photos to Site Scan Manager for ArcGIS. There are two methods for imagery import: wireless and through SD card reader.
Wireless import is the simplest way to get imagery from drone to tablet. It works well for single missions, or multiple missions with a low number of total images.
Note: The connected status merely indicates which vehicle ArcGIS Flight is connected to. However, users must verify that the connected vehicle is the same vehicle used to capture the imagery for the selected mission(s). Otherwise, ArcGIS Flight will fail to locate mission imagery on the connected vehicle.
Optionally, you can enable Upload to Site Scan After Importing or Quick Upload Copy of Mission to automatically upload imagery to your Site Scan organization. If enabled, these processes will only start once all imagery has successfully been imported from the selected missions. If internet connection is inadequate, upload will not occur but images will remain imported in ArcGIS Flight.
Memory card is the fastest way to import multiple missions at once, and does not rely on connection strength between the drone and tablet.
Users can also elect to create missions from a set of drone imagery.
Merge Multiple Imported Missions
Upload Imagery from Imported Missions
Single Mission Upload
Multi Mission Upload
Article ID: 000026165
Get help from ArcGIS experts
Download the Esri Support App
