PROBLEM
ArcGIS Dashboards pop-ups display empty results
Last Published: May 6, 2020
When selecting features from a map in ArcGIS Dashboards, the pop-ups display empty results.
Empty result in pop-up
Cause
This issue occurs when the Theme and Text Color settings are set to the same color in ArcGIS Dashboards.
Solution or Workaround
Perform the following steps to resolve the issue.
  1. Launch ArcGIS Dashboards in ArcGIS Online or Portal for ArcGIS.
  2. In the top panel, click Settings Image of Settings icon.
  3. In the Dashboard Settings window, select the Theme tab.
  4. If Theme is set to Light, set Text Color to black, and click Done.
Alternatively, in the Layout banner, click Reset to restore the default color settings, where Theme and Text Color are set to contrasting colors.
Article ID: 000023135
Software:
  • Mobile Applications
  • ArcGIS Online
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
