HOW TO
Populate a date field with a current date using Python
Last Published: July 20, 2023
Summary
In ArcGIS Desktop, a date field can be populated with the current date using the Field Calculator in ArcMap or the Calculate function in ArcGIS Pro. The Python parser in the field calculator provides the time.strftime('%d/%m/%Y') function to do so. Alternatively, the current date can also be populated using the UpdateCursor() function.
Procedure
The following steps describe how to populate a field with the current date using a Python script.
  1. Import the necessary modules.
import arcpy, datetime
  1. Specify the location of the geodatabase and the desired field.
fc = r'C:\Test\Test1.gdb\Feature_1'
field = "Date_Field"
  1. Start a loop with the UpdateCursor() function to populate the selected field with the current date.
with arcpy.da.UpdateCursor(fc, [field]) as rows:
    for row in rows:
        rows.updateRow([datetime.date.today()])
The following shows the full script:
fc = r'C:\UsersUSER1\Desktop\Data\Database1.gdb\Sample'
    for row in rows:
Article ID:000023088
Software:
  • ArcMap
  • ArcGIS Pro 2 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
