PROBLEM
A polygon split outputs polygons with null values in the attribute table in ArcGIS Pro
In ArcGIS Pro, a polygon split using the Split tool on the Edit ribbon tab outputs polygons with null values in some or all of the fields of the attribute table, as shown in the images below.
Image of polygon split using the Split tool
Cause
This is by design. The split policy for the geodatabase attribute domain is set to Default, resulting in output polygons having a default value. In some cases, the value is null.
Solution or Workaround
Before splitting the polygon feature, set the geodatabase split policy to Duplicate to retain the attributes of the original polygon after a split in Domains.
  1. In the Catalog pane, right-click the geodatabase where the feature class resides, and click Domains .
  2. For Split Policy, select Duplicate from the drop-down list.
Image of the Split policy set to Duplicate
  1. Click Save Image of the new domain fields.
The image below shows output polygons retain the original polygon attributes after it is split.
Image of the output polygon attribute table with the duplicated attributes
Article ID:000022685
Software:
  • ArcGIS Pro 2 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
