English
Error: Error 1935: An error occurred during the installation of assembly
Error Message
When attempting to install ArcGIS Desktop, the following error occurs:
"Error 1935: An error occurred during the installation of assembly 'Microsoft.lnk,Version="1.7.2600.2180", Publickey Token="31BF3856AD364E35",Culture="neutral".
Please refer to Help and Support for more information.
HRESULT=0x80131700"
Cause
1935 errors usually indicate that something is wrong with a .NET assembly or the .NET installation.
Solution or Workaround
Uninstalling and reinstalling the .NET Framework is a solution that can potentially resolve these issues.
  1. Navigate to Start > Control Panel > Add/Remove Programs.
  2. Select Microsoft .NET Framework from the list and select Remove. If there are multiple versions installed, remove them all, one at a time.
  3. Reinstall the highest version of Microsoft .NET Framework that was previously installed. Download links are provided below under Related Information.
  4. Start the installer for ArcGIS Desktop again.
Related Information
Last Published: 10/9/2019
Article ID: 000010394
Software: ArcMap 10.4.1, 10.4, 10.3.1, 10.3, 10.2.2, 10.2.1, 10.2, 10.1, 10
