Technical Paper
Mapping with Vector Tiles
Published: July 13, 2026
Summary
From making to sharing, vector tile users have many options in ArcGIS Pro, supported by detailed help pages and guidance. However, the sequence of setting up a map and generating vector tiles with the right combination of settings is not always obvious, particularly when what appears on screen as input does not always match the published result. This paper explores some of the most common sticking points and outlines a practical, end‑to‑end workflow.
ArcGIS Pro is a mature, professional GIS with an extensive set of tools and configuration options designed to support a wide range of mapping workflows. This breadth of functionality can make it challenging to focus on the specific requirements of authoring vector tiles. Vector tile authors must be able to define scale‑dependent styling behavior and understand precisely what will be shown, how it will be rendered, and why. The ArcGIS Pro interface does not always make these vector‑tile‑specific behaviors explicit, contributing to a gap between authoring intent and published outcomes.
The aim of this paper is to provide a practical bridge between intended map styling and real‑world results. It addresses the more common questions and frustrations encountered in practice, shedding light on how vector tiles work and how to best prepare and publish them using ArcGIS Pro and the wider ESRI ecosystem
Supporting Files
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
