Technical Paper
ArcGIS Server in Practice Series: High Capacity Map Services: A Use-Case with CORINE Land Cover Data
This document provides practical information on how to implement high-capacity map services with ArcGIS Server using the CORINE Land-Cover data as an example. It presents example ArcGIS Server system deployments, their performance metrics, and a collection of tips and deployment considerations for high-capacity map services using ArcGIS Server Standard Enterprise edition.
This document discusses strategies for creating a dynamic map service that supports heavy user loads. It describes some tips and best practices for developing a map service that can generate over 250,000 maps per hour dynamically. The map service also supports on-the-fly projection, is multiscale, and enables feature filtering. The document also explores strategies for scalable deployments of ArcGIS Server.
Supporting Files
Get help from ArcGIS experts
Download the Esri Support App
