PROBLEM
Z and M values are not returned for some features in a feature layer hosted in ArcGIS Online
Querying features in an ArcGIS Online hosted feature layer returns Z or M values only for some features, even though the source data contains Z or M values.
Cause
When the source feature geometry is invalid, ArcGIS Online rebuilds the geometry before storing it. Z and M values do not persist when ArcGIS Online rebuilds an invalid geometry.
Solution or Workaround
Correct the feature geometry to meet OGC standards before publishing a hosted feature layer to ArcGIS Online.
If the data source is a shapefile or file geodatabase, complete the following procedure to check source files and correct invalid geometries before publishing.
  1. In ArcGIS Pro, run the Check Geometry geoprocessing tool with the validation method set to OGC on shapefiles and file geodatabase feature classes before publishing.
  2. If the Check Geometry geoprocessing tool indicates there are invalid geometries, create a backup copy of the source file.
  3. In ArcGIS Pro, run the Repair Geometry geoprocessing tool with the validation method set to OGC on any shapefiles or file geodatabase feature classes that contain invalid geometries.
Article ID: 000020405
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
