BUG
The downloadable OGC WMS Connector generates incorrect styles.xml files. The connector uses the ArcIMS layer's name instead of the ArcIMS layer's ID.
This is a known issue.
Code:
<?xml version="1.0" encoding="UTF-8"?>
<sld:StyledLayerDescriptor ... version="1.0.0">
<sld:NamedLayer>
<sld:Name>Ocean</sld:Name>
</sld:NamedLayer>
<sld:NamedLayer>
<sld:Name>Country</sld:Name>
</sld:NamedLayer>
<sld:NamedLayer>
<sld:Name>Cities</sld:Name>
</sld:NamedLayer>
</sld:StyledLayerDescriptor>
However, the code needs appear as follows where the layer names are actually ArcIMS layer IDs:
Code:
<sld:NamedLayer>
<sld:Name>0</sld:Name>
</sld:NamedLayer>
<sld:NamedLayer>
<sld:Name>1</sld:Name>
</sld:NamedLayer>
<sld:NamedLayer>
<sld:Name>2</sld:Name>
</sld:NamedLayer>
Edit the file and make the necessary change with a text editor.
Warning:
Each time the capabilities file is updated through the WMS Connector Administrator interface it writes over this file with the incorrect values. Create a backup of this file before updating the capabilities files.
Article ID:000007017
Get help from ArcGIS experts
Download the Esri Support App
