Frequently asked question
Why must arcpy.sa functions be assigned to a variable?
First Published: May 5, 2016
The arcpy.sa functions are temporary, therefore, the arcpy.sa function must be assigned to a variable. Otherwise, the output does not persist, and is unusable in scripts.
A variable holds references to data. In this example, the raster object created with an arcpy.sa function is stored in a variable named Solar.
Code:
import arcpy;
from arcpy.sa import *;
arcpy.CheckoutExtension ("Spatial"); #Code used to check the extension in ArcMap
Solar = arcpy.sa.AreaSolarRadiation (inRaster, latitude, time);
# the code segment uses the arcpy.sa
The output raster is temporary by default. Due to the volatile nature of the output raster, it must be assigned to a variable to retain the output raster value.
Article ID: 000012410
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
