Frequently asked question
Why is the PMF not readable by ArcMap when published using ArcObjects?
Answer
The IPMF::PMFSettings property, used when publishing a map document to a PMF using ArcObjects has two Application settings.
The documentation in the ArcObjects Developer Help for the Application strings are incorrect.
The correct Application strings for IPMF::PMFSettings are:
"OpenOnlyInArcReader"
"InternalObjectAccess"
To publish a map document to a PMF that is readable by ArcMap, set the application strings as follows:
"OpenOnlyInArcReader", False
"InternalObjectAccess", True
It is necessary to set both Application strings to be able to open the resulting PMF file in ArcMap. If both are true, OpenOnlyInArcReader takes precedence, and the resulting PMF will not be readable by ArcMap.
Article ID:000007630
Software:
  • ArcMap 9 x
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
