Frequently asked question
Why does the SimpledataLoader and the ObjectLoader map RDBMS integer fields to doubles?
When you export long integers from Oracle they are mapped to a double to avoid overflow. Oracle does not have a true long integer type, using a number(10), which can contain numbers larger than will fit into a long. This also is a problem with short integers, which map to a long integer on export.
Currently the ObjectLoader UI does not allow the mapping of larger fields to smaller fields. This could be changed, but at the risk of having some imports failing in the middle of the load when a field is too wide.
The workaround is to use double rather than long integer when you plan on constantly importing and exporting data into the same template.
Article ID: 000005494
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
