Frequently asked question
Why does the map extent shift when it is exported to PDF?
First Published: May 5, 2016
The map extent shifts or moves when the map is exported to PDF because Data Driven Pages are enabled in the map document.
If users want to print a map outside of the logical bounds of the Data Driven Pages, they must do one of the following:
• Add a custom extent to the data driver for Data Driven Pages.
1. In ArcMap, navigate to Customize > Toolbars > Data Driven Pages.
2. On the Data Driven Pages toolbar, click the Data Driven Pages setup button.
[O-Image]
3. In the Set Up Data Driven Pages dialog box, click the Extent tab.
[O-Image]
4. Set the desired custom extent.
[O-Image]
5. Click OK.
• Disable Data Driven Pages.
3. In the Set Up Data Driven Pages dialog, uncheck the Enable Data Driven Pages check box.
[O-Image]
Article ID: 000012160
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
