Frequently asked question
Why can't I see my EPS export files in Adobe Illustrator or Macromedia Freehand?
ArcMap does not include a preview or thumbnail with its EPS export files. Graphics applications use this preview to display the file. In its absence, you will only see the bounding box of the EPS file.
The file will print correctly even though you cannot see or edit it.
This problem affects Illustrator only if the Place command is used to import the file. Use the Open command to import the EPS as an editable graphics file. Freehand cannot import an ArcMap EPS as an editable file.
Article ID: 000002761
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
