PROBLEM
The contents of some OLE DB tables listed in the TOC window in ArcCatalog cannot be previewed.
AN OLE DB connection will return a list of table names which includes:
a) Any table(s) you own.
b) Any table(s) you have been granted "object privileges" on (select, delete, insert, update, index, references, and alter).
c) Any table(s) where any of the object privileges have been granted to a role assigned to you, for example, the "Public" user group or role.
OLE DB tables are returned as unqualified database objects when you try to view the contents of a table not owned by you, the table cannot be identified correctly to return all the rows.
1. Create a public synonym for the table.
Examples:
For DB2:
Code:
CREATE NICKNAME <nickname> FOR <table>
Code:
CREATE PUBLIC SYNONYM <schema>.<synonym> FOR <SCHEMA>.<OBJECT>;
2. Assign the public role to the user who is accessing the tables.
Examples:
For DB2:
Code:
GRANT <user> ON <nickname> TO PUBLIC
Code:
GRANT PUBLIC TO <user>;
Unqualified database objects are identified only by the object name and not by the fully qualified database name of <object owner.object name> e.g. user1.mytable, or <database name.object owner.object name> in the case of DBMS packages which support multiple databases.
Article ID:000001957
Get help from ArcGIS experts
Download the Esri Support App
