Frequently asked question
Why are there two update dates on the item details page in ArcGIS Online?
Last Published: December 31, 2021
The item details page for an item in ArcGIS Online shows the date of the last updates for an item. There are two update dates listed on this page and each traces certain types of updates.
example item details page
The Updated field at the top of the item details page (next to the thumbnail) tracks the updates made to the item in ArcGIS Online, for example, the name of the item or layers, description, metadata, and so forth.
Under the Details section on the right side of the pane, the Data Last Updated date shows the last update made to the content of a data or the schema, for example, editing an attribute, adding a feature, adding a new field, etc.
Some changes update both fields. For example, changing the layer style from the Visualization tab or enabling and/or disabling editing (because it also changes the attribute indexes).
However, there are other changes that apparently are not tracked in either field. For instance, changing the ownership or sharing settings of an item.
Article ID: 000026831
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
