Frequently asked question
Why are there raster artifacts visible in hillshade results when something is performed on a projected DEM?
Answer
DEMs are susceptible to artifacting. Many DEMs already have some artifacts introduced during creation; hillshades of those DEMs will magnify the anomalies and make them visible. If the DEM does not have any artifacts before it is rendered as a hillshade, the problem may be caused by using an improper resampling method when projecting the DEM data.
A DEM is continuous raster data. The bilinear resampling method should be used in raster projections or any raster transformations. When projecting raster data using the Project Raster GP tool, do not use the default resampling method. Choose bilinear resampling or cubic convolution resampling method instead.
Warning:
In ArcGIS 9.0, there is a problem in setting the correct resampling method. Choosing bilinear or cubic resampling will always use default nearest neighbor resampling. This problem has been fixed in 9.1.
Article ID:000007882
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
