Frequently asked question
Where can a detailed list of privileges required on Workflow Manager system tables be found?
First Published: June 2, 2016
Last Published: April 26, 2020
Esri provides the following document entitled, ArcGIS Workflow Manager Database Design Doc.pdf.
This document is installed with ArcGIS Workflow Manager Desktop, and is located in the Help folder. For example:
C:\Program Files (x86)\WMX\Desktop10.1\Help\ ArcGIS Workflow Manager Database Design Doc.pdf
[O-Image] WMX_locale
Within this .pdf document, a summary of the ArcGIS Workflow Manager user privileges can be found in Appendix A. The guidelines shown for the WMX user are based on that user having all WMX application privileges.
WMX Administrators must have select, update, insert, and delete privileges on all WMX system tables.
Article ID: 000013266
Software:
  • Legacy Products
  • ArcMap
  • ArcGIS Workflow Manager for Server
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
