ERROR
When validating objects in ArcMap, using the Validate Selection command, or when using IValidation::Validate, some objects that break relationship cardinality rules are not returned as being invalid.
Cardinality rules on composite relationships are not being evaluated by the system. Cardinality rules on simple relationships are evaluated correctly.
The workaround for this problem is to create a class extension that implements IObjectClassValidation. In the IObjectClassValidation_ValidateRow method, you can write code to manually validate the relationship rules cardinality.
For an example of how to implement a custom rule, see the developer samples:
Samples\Geodatabase\Class Extensions\Implementing the IObjectCLassValidation Class Extension Interface.
Article ID:000003370
Get help from ArcGIS experts
Download the Esri Support App
