BUG
When revoking privileges on a versioned feature class, the select privileges are not revoked from the versioned table's adds and deletes tables.
Even though the privileges are not revoked from the adds and deletes tables, users will not be able to select or edit the versioned table with ArcGIS. However, the users will continue to have access to the tables directly with SQL. This may be considered a security risk.
The cause of the problem resides in the ArcSDE function, which revokes privileges from objects. The adds and deletes tables are mistakenly skipped when privileges are revoked.
Code:
SQL> SELECT registration_id FROM sde.table_registry WHERE table_name = 'GAS_MAINS';
REGISTRATION_ID
45
Code:
SQL> REVOKE SELECT ON a45 FROM brent;
Revoke succeeded.
SQL> REVOKE SELECT ON d45 FROM brent;
Revoke succeeded.
Article ID:000010273
Get help from ArcGIS experts
Download the Esri Support App
