Frequently asked question
When I use the create on intersect tool why do my features get set back to their defaults?
First Published: May 5, 2016
When PLTS attribution center is up it will split features based on the way their split policy was defined in the geodatabase. If you close the PLTS attribution center during an edit session intersected features will not observe the way their split policy was defined and their values will be set back to default. In order to avoid this problem you must leave the PLTS attribution center open and visible on your screen until the editing session has been saved.
Article ID: 000006344
Software:
  • ArcGIS Production Mapping
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
