PROBLEM
When editing joined data, some fields are not editable in the table window
First Published: May 5, 2016
When an edit session is started and an attribute table is opened for joined data, some fields are not editable.
Cause
A field is not editable if it is a joined field or the field in the target layer has the same name as a joined field.
Solution or Workaround
Edit the join table independently. Changes made to the join table are applied to the join.
Article ID: 000002967
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
