ERROR
The following error message occurs when adding or creating a point theme or when geocoding:
"AVArray: Index 0 not in range 0..-1"
Note: The content in this article pertains to retired products, ArcView GIS versions 3.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
ArcView is using an empty marker palette.
Note: At least one should be located in the \esri\av_gis30\arcview\symbols directory. Additional copies of default.avp may be found in the home directory or in the Windows\Temp directory.
Warning: Make sure to not delete or rename the default.avp file located in \esri\av_gis30\arcview\symbols.
Article ID:000004091
Get help from ArcGIS experts
Download the Esri Support App
