Frequently asked question
An 'if' clause can be used to determine the next steps within the Python code after a button is clicked. For example:
Code:
import arcpy
import pythonaddins
class Open(object):
"""Implementation for Dialog_addin.OpenButton (Button)"""
def __init__(self):
self.enabled = True
self.checked = False
def onClick(self):
#Define the map document and data frame
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd,"*")[0]
#Call the open dialog
openValue = pythonaddins.OpenDialog("Open Dialog", False, r"C:\temp", "Open")
#Make sure dialog was not canceled.
if openValue != None:
#Create the layer
rasterLayer = arcpy.mapping.Layer(openValue)
#Add the layer to the map document
arcpy.mapping.AddLayer(df, rasterLayer,"TOP")
# Refresh map document
arcpy.RefreshActiveView()
arcpy.RefreshTOC()
del mxd, df, openValue
else:
pythonaddins.MessageBox("No data will be added to the map document.", "Warning Message", 0)
Article ID:000011626
Get help from ArcGIS experts
Download the Esri Support App
