Frequently asked question
What happened to background geoprocessing in ArcGIS Pro?
First Published: May 5, 2016
In 32-bit ArcGIS for Desktop, the background geoprocessing function works by using a separate 64-bit process to perform the analysis, which is why 64-bit Background Geoprocessing must be installed separately. When invoked, it is seen in Task Manager as two RuntimeLocalServer.exe processes.
Since ArcGIS Pro is itself a 64-bit application, a separate process for background geoprocessing is no longer needed. Tools are run asynchronously, not on a separate task that appears in Task Manager, and allow work to continue in the application while they execute.
As of this writing, additional functionality to run tools in a separate process is being considered.
The in memory workspace option is available for models and scripts in which it is used as intermediate storage for tools chained in sequence. When running tools individually in the Geoprocessing pane or from a Python window, the project default geodatabase is substituted for the in_memory workspace.
Article ID: 000012074
Software:
  • ArcMap
  • ArcGIS Pro
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
