Frequently asked question
Code:
SG_SUCCESS 0
SG_FAILURE (-2000) General failure error
SG_INVALID_SHAPE_OBJECT (-2001) Invalid shape object handle
SG_INVALID_POINTER (-2002) Specified pointer value is null or invalid
SG_INVALID_PARAM_VALUE (-2003) Specified parameter value is invalid
SG_INVALID_SHAPE (-2004) Invalid shape, can not be verified
SG_INVALID_PARTNUM (-2005) Specified part doesn't exist in the shape
SG_INVALID_ENTITY_TYPE (-2006) Invalid shape entity type
SG_INCOMPATIBLE_SHAPES (-2007) The shapes are of incompatible types
SG_SHAPE_INTEGRITY_ERROR (-2008) Model integrity error
SG_INVALID_SEARCH_METHOD (-2009) Invalid search method
SG_INVALID_END_POINT (-2010) Specified end point is invalid
SG_INVALID_RADIUS (-2011) Specified radius is invalid
SG_TOO_MANY_POINTS (-2012) Too many points generated by this operation
SG_ALL_SLIVERS (-2013) Sliver factor caused all results to be slivers
SG_POINT_NO_EXIST (-2014) Specified point doesn't exist in the shape
SG_BUFFER_OUT_OF_BOUNDS (-2015) Resulting buffer exceeds valid coordinate range
SG_INVALID_SYSTEM_UNITS (-2016) Systems units < 1 or > 2147483647.
SG_PATH_NOT_FOUND (-2017) Coord path not found in shape edit op.
SG_OUT_OF_MEMORY (-2018) Out of memory
SG_INVALID_PART_OFFSET (-2019) Part offset is invalid
SG_INCOMPATIBLE_COORDREFS (-2020) The given coordinate references are incompatible
SG_COORD_OUT_OF_BOUNDS (-2021) The specified coordinate exceeds the valid coordinate range
SG_INVALID_ENVELOPE (-2022) The given envelope is NULL, has negativevalues, or min > max
SG_INVALID_COORDREF_OBJECT (-2023) Invalid coordinate reference object handle
SG_INVALID_COORDSYS_ID (-2024) Invalid identifier for a coordinate system
SG_INVALID_COORDSYS_DESC (-2025) Invalid description for a coordinate system
SG_PROJECTION_ERROR (-2026) Error projecting shape points
SG_POLY_SHELLS_OVERLAP (-2027) 2 donuts or 2 outer shells overlap
SG_TOO_FEW_POINTS (-2028) numofpts is less than required for feature
SG_INVALID_PART_SEPARATOR (-2029) part separator in the wrong position
SG_INVALID_POLYGON_CLOSURE (-2030) polygon does not close properly
SG_INVALID_OUTER_SHELL (-2031) A polygon outer shell does not completely enclose all donuts
for the part
SG_ZERO_AREA_POLYGON (-2032) Polygon shell has no area
SG_POLYGON_HAS_VERTICAL_LINE (-2033) Polygon shell contains a vertical line
SG_OUTER_SHELLS_OVERLAP (-2034) Multipart area has overlapping parts
SG_SELF_INTERSECTING (-2035) Linestring or poly boundary is self-intersecting
SG_READ_ONLY_SHAPE (-2036) Attempted to modify read-only shape
SG_INVALID_NUM_MEASURES (-2037) Number of measures in binary is invalid
SG_INVALID_NUM_PARTS (-2038) Number of parts in binary is invalid
SG_BINARY_TOO_SMALL (-2039) Shape won't fit in supplied binary
SG_INVALID_BYTE_ORDER (-2040) WKB shape byte order is invalid
SG_INVALID_GEOMETRY_TYPE (-2041) Invalid shape's geometry type
SG_SHAPE_TEXT_TOO_LONG (-2042) Length of shape text exceeding the allocated buffer size
SG_AMBIGUOUS_NIL_SHAPE (-2043) No SQL type provided when converting NIL shape to text
SG_TYPE_MISMATCH (-2044) Unexpected shape SQL type
SG_SQL_PARENTHESIS_MISMATCH (-2045) Parenthesis mismatches in shape text
SG_SHAPE_TEXT_ERROR (-2046) Syntax error in shape text
SG_TOO_MANY_PARTS (-2047) Shape has too many parts
SG_NIL_SHAPE_NOT_ALLOWED (-2048) NIL shape is not allowed for WKB
SG_SCL_SYNTAX_ERROR (-2049) SCL Language Syntax Error
SG_INVALID_PRECISION (-2050) Bad or default precision specified
SG_SPATIALREF_NO_CLUSTER_TOL (-2051) No cluster tolerance properties persisted in this spatial
reference schema
SG_NOT_IMPLEMENTED_YET (-2999) Function or option has not been implemented
Article ID: 000008067
Get help from ArcGIS experts
Download the Esri Support App
