Frequently asked question
Attempting to access the arcpy.time module generates an error similar to the following:
module 'arcpy' has no attribute 'time'
The arcpy.time python module was deprecated and removed at ArcGIS Pro version 3.0.
In addition to Map Time, Layer Time and Time Zone functionality in the arcpy.mp python module, ArcGIS Pro 3.0 has been updated to Python 3.9, which has additional time support. Below are examples of common workflows.
Alternatives to arcpy.time.EsriTimeDelta
There are a couple of options to use core Python, that is, non-ArcPy time deltas. Firstly, there is the datetime.timedelta type. The datetime.timedelta supports units of days, seconds, and milliseconds. Secondly, the dateutil library relativedelta type supports all date units, such as months, years, etc.
More information on datetime.timedelta and dateutil.relativedelta can be found in the Python 3.9.13 Documentation: datetime — Basic date and time types. The following is an example:
from datetime import datetime from dateutil.relativedelta import relativedelta time = datetime(2011, 1, 1) for delta in range(0, 12): next_date = time + relativedelta(months=delta) print(next_date)
Starting at ArcGIS Pro version 2.8, arcpy.mp added support for LayerTime and MapTime. These classes do not use EsriTimeDeltas. LayerTime intervals are expressed as timeStepInterval and timeStepIntevalUnits. MapTime intervals are expressed as currentTimeSpan, currentTimeSpanUnits, timeStepInteval and timeStepIntevalUnits.
The MapTime class also has a timeStep method that returns a new time based on a given reference time and a time interval. The Python datetime object returned from the timeStep method can be used to set the currentTimeStart and currentTimeEnd properties. To create a temporal map series, use the timeStep method to iterate through time values.
Here is an example of LayerTime timeStepInterval:
import arcpy aprx = arcpy.mp.ArcGISProject('C:/Project/Temperature.aprx') m = aprx.listMaps('USA')[0] lyr = m.listLayers('temperature')[0] t = lyr.time print(t.timeStepInterval) print(t.timeStepIntervalUnits)
Here is an example of MapTime currentTimeSpan:
import arcpy aprx = arcpy.mp.ArcGISProject('C:/Project/Temperature.aprx') lyt = aprx.listLayouts()[0] mf = lyt.listElements('MAPFRAME_ELEMENT')[0] mt = mf.time print(mt.currentTimeSpan) print(mt.currentTimeSpanUnits)
Alternatives to arcpy.time.ListTimeZones
Use arcpy.mp.ListTimeZones. For example:
import arcpy tzList = arcpy.mp.ListTimeZones("*Canada*") print(tzList)
Alternatives to arcpy.time.TimeZoneInfo
Use zoneinfo, which is new in Python 3.9. More information can be found in the Python 3.9.13 Documentation: zoneinfo — IANA time zone support
Zoneinfo example 1:
from datetime import datetime from zoneinfo import ZoneInfo from dateutil.relativedelta import relativedelta tzinfo = ZoneInfo('US/Pacific') time = datetime(2011, 1, 1, tzinfo=tzinfo) for delta in range(0, 12): next_date = time + relativedelta(months=delta) print(next_date, tzinfo.tzname(next_date))
Zoneinfo example 2:
from datetime import datetime from zoneinfo import ZoneInfo from_tzinfo = ZoneInfo('US/Pacific') target_tzinfo = ZoneInfo('US/Eastern') from_time = datetime.now(from_tzinfo) print("target_time =", str(from_time.astimezone(target_tzinfo)))
Article ID: 000027752
Get help from ArcGIS experts
Download the Esri Support App
