Frequently asked question
"Error: The local edits were not synchronized to the server. The server took too long to answer."
Note: Clients can use a service for a certain duration of time once the clients receive a reference to the service. After a specific amount of time, the service is released from the clients. Synchronizing huge edits may cause a client to use a service exceeding the maximum usage time, resulting in timeouts. As a result, the client loses the reference to the service. For more information, refer to the following document, ArcGIS Help: Timeouts
A new item is created in the ArcGIS Online root folder when local edits are republished as a new feature service. The new item is assigned a new ID although the same name is maintained. Although a new ID is assigned to new items, sharing and other properties such as previously saved symbology or pop-up windows must be reconfigured. For more information, refer to the following document: ArcGIS Help: Publish hosted feature layers
Article ID: 000012872
Get help from ArcGIS experts
Start chatting now
