Frequently asked question
What are alternatives to an ODE/Java applet solution?
Answer
Some Open Development Environment (ODE) solutions require a specialized setup on the client machines. If you are simply serving maps, consider ArcIMS.
The only time an ODE solution warrants the effort of client setup is to provide capabilities that only ArcInfo has. In that case, the first suggestion is to write a Java application rather than an applet. The trouble of setting up a machine to run an ODE applet usually outweighs the benefit gained because the main goal of an applet is to avoid requiring end users to install anything.
Article ID:000004669
Software:
  • Legacy Products
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
