PROBLEM
WGS 1984 is not what you think!
First Published: June 11, 2025
Last Published: July 22, 2025
In the European Petroleum Survey Group (EPSG) database, the World Geodetic Survey 1984 (WGS 1984 wkid 4326) is not one single geographic coordinate reference system. Instead, it is an 'ensemble' or bucket, that contains all definitions or realizations of WGS 1984. Each realization, or version, of WGS 1984 is specified by a reference to the GPS week for which it was calculated.
For example, the current realization in 2025 is WGS 1984 (G2296). Each realization (G730, G873, G1150, G1674, G1762, G2139, G2296) are all defined based on the locations of a set of control points on a specific date. That date is referred to as the epoch for the datum and geographic coordinate reference system.
A new WGS 1984 realization reflects the Earth's crustal motion changes over time, including tectonic plate or seismic movement, post-glacial rebounding, or subsidence.
Because GCS_WGS_1984 is not one single definition, a user cannot transform from WGS_1984 to WGS_1984_(G1762) for example, because WGS_1984 is not a single thing. To access a specific transformation going TO WGS_1984_(G1762), the user must specifically define the starting point, whether they are starting from WGS_1984_(G730), from WGS_1984_(G1150) or some other realization of WGS_1984.
Depending on the starting point, several transformations may be required to get to the desired one. For example, if the original data uses WGS84(G1674), three successive transformations are used to get to WGS84(G2296):
  1. WGS_1984_G1674_To_G1762_Fixed_At_2012.5_KD
  2. WGS_1984_G1762_To_G2139_Fixed_At_2016.0_NGA
  3. WGS_1984_G2139_To_G2296_Fixed_At_2024.0_NGA
Cause
The latest lists of the components of the Projection Engine can be viewed and downloaded from the following article: Coordinate systems, map projections, and transformations
On the list of Geographic Datum Transformations, scroll to page 77 for the list of transformations between the realizations of WGS 1984.
To apply these transformations, the user needs to know which realization of WGS 1984 they are using and have that specific definition applied to their data to call the appropriate transformation on the projection engine.
Solution or Workaround
Datum realizationImplementation dateReference epochAccuracy (m)Aligned to
*WGS84(Doppler)1987, 1 JanuaryNA1-2BTS 1984
*WGS84(G730)1994, 29 June1994.00.10ITRF91
*WGS84(G873)1997, 20 January1997.00.05ITRF94
*WGS84(G1150)2002, 20 January2001.00.01ITRF2000
*WGS84(G1674)2012, 8 February2005.0<0.01ITRF2008
*WGS84(G1762)2013, 16 October2005.0<0.01ITRF2008
*WGS84(G2139)2021, 28 March2016.0<0.01ITRF2014
**WGS84(G2296)2024, 4 MarchPPP<0.01ITRF2020 and IGS20
*Data from: Transforming between WGS84 Realizations
**Data from: Thirty Years of Maintaining WGS 84 with GPS, Section 2.2 Alignment Through PPP, and WGS 84 (G2296) Terrestrial Reference Frame Realization
WGS 1984 Epoch Transformations
WGS_1984_G1150_To_G1674_Fixed_At_2007.5_KD108468
WGS_1984_G1674_To_G1762_Fixed_At_2012.5_KD108469
WGS_1984_G1762_To_G2139_Fixed_At_2016.0_NGA108474
WGS_1984_G2139_To_G2296_Fixed_At_2024.0_NGA108477
WGS_1984_G2296_To_ITRF2020_NGA108478
WGS_1984_G730_To_G873_Fixed_At_1995.5_KD108466
WGS_1984_G873_To_G1150_Fixed_At_1999.5_KD108467
WGS_1984_Transit_To_G730_Fixed_At_1990.5_KD108465
Article ID: 000036058
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
