PROBLEM
Webroot Spy Sweeper software can cause Python geoprocessing scripts to fail in ArcGIS
First Published: May 5, 2016
Built-in scripts, such as 'Raster to Geodatabase (multiple)', or custom scripts added to a toolbox fail with:
Executing (RasterToGeodatabase_4): RasterToGeodatabase C:\temp\12t185615 "Database Connections\Raster.sde\Raster.RASTERDB.Ortho2004Color" # "Database Connections\Raster.sde\Raster.RASTER.Ortho2004Color"
Start Time: Tue Nov 16 14:16:20 2004
Running script RasterToGeodatabase...
Error in script RasterToGeodatabase.
Error in executing: cmd.exe /C C:\PROGRA~1\ArcGIS\ARCTOO~1\Scripts\RASTER~1.PY "C:\temp\12t185615" "Database Connections\Raster.sde\Raster.RASTER.Ortho2004Color" "#" "Database Connections\Raster.sde\Raster.RASTER.Ortho2004Color"
Cause
Webroot's Spy Sweeper Enterprise software is installed and is not allowing scripts to process.
Solution or Workaround
  1. Open Webroot Spy Sweeper.
  2. Open Options.
  3. Select Active Shields.
  4. Disable Spy Installation.
Article ID: 000007585
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
